wtf mate no brakes?
well if you want you can bring it by and i can look at your brakes just to be on the safe side because your brakes definitely should not be doing that. even though they feel better now there definitely is a problem and should at the least be looked at by someone
ಠ_ಠ Haters gonna hate ಠ_ಠ
if u need a cylinder u might as well do the booster also.
i just did mine in my EF and when u get the Cylinder OR the booster it even says in the box "MAY NEED NEW BOOSTER" or "MAY NEED NEW CYLINDER"
Cuz what happens is the seals between the cylinder and the booster goes bad and brake fluid leaks into the booster making both parts no good. air in a hydraulic system is what makes it go straight to the floor.
Replace them both bleed all ur brakes DONT FORGET TO BLEED THE MASTER CYLINDER!!
1990 Honda Civic DX Hatchback - SOLD
2006 Scion tC - Traded
2013 Fiat 500 Abarth - Current DD
im going threw the same thing my brakes grab sometimes and then sometimes dont but im changing mine out today, its most likely your cylinder or possibly the booster and most auto parts stores have a core charge, it shouldnt be 80$ its more like 40$ if you bring in the old one, its around 75 if you dont but its a dumb decision to not take it back your gonna throw it away anyways, but i could be off thats the price of a cylinder for a 92 integra with abs,
"Life is simple, make choices and don't look back."
TR "Old Skool Db" Member #01
1994 Acura Integra LS (Coupe)
1992 Acura Integra LS (Sedan)
1991 Acura Integra LS (sedan)
1991 Acura Integra LS (coupe)
1997 Acura Integra LS (coupe)
1998 Honda Civic DX (hatch)
2006 Honda CBR 600RR
1999 Jeeo Cherokee 4x4
2005 Dodge Neon SRT-4
