ECT sensor
Old Jan 22, 2002 | 09:54 AM
KJ's Avatar
KJ
bored at work
Even on the 92+ blocks there is still a place tapped in for the ect sensor with the two nipples all you have to do is just remove the plug. The stock d-series ect sensor is the same as the older ls and b16a1. Ive always just run the ect sensors like this and did the same on my lsvtec(92 ls block). Im not sure but the ect sensor in the t-stat housing might operate at different voltage readings and they might be upsetting the pr3 ecu that was programmed with the green two nipple type sensor. Not saying thats deffinitely the answer but just what has worked on lsvtecs for me.
edit: the d-series ect sensor I was refering to was 88-91.
Old Jan 22, 2002 | 09:16 PM
KJ's Avatar
KJ
bored at work
Originally posted by "Someone"
Originally posted by j99jm
no they are different... i took the green one out of a b16 and it was covered in what looked like a mixture of oil and coolant... so it reads temerature from a liquid the sensor (in the exact location) on the 94+ block is a single plug with two wires that looks like a knock sensor that is just metal that screws into metal... im really perplexed with this whole fuckin thing.... WE NEED VTEC DAMNIT! thank you for the reply.
That sensor with the green plug is an ls only oil temp sensor which isnt necessary. That sensor goes into an oil passage. Under the water pipe look for a plug and unscrew it the ect sensor screws into that one which is a coolant passage.
jjpast
Feb 6, 2001 11:32 AM
S&P500Si
Oct 11, 2000 04:48 AM
sy2173
Sep 28, 2000 01:00 PM
