Teg Trans Problem!!!
hey guys...I need a second opinion on these issues my car is having....first off my trans and clutch never had any major issues...besides a squeaky throwout bearing and occasionally it would give me a little trouble going into 1st....but as of last night I lost all my "up" gears.....1st 3rd and 5th are gone.....I havent checked the fluid just yet but I will be looking into that tomorrow and will be looking at the linkage....Im almost certain its something fluid or linkage related....possibly clutch related but not sure yet...I dont think the tranny grenaded only because the problem came so suddenly.....any feedback would be appreciated
engine building &best
on
how olds the clutch?if the clutch set is to worn then the problems you stated are able..have someone under the hood while you push in the clutch to see if the slave is pushing the lever out all the way....does the pedal feel softer?
i love AUTOZONE
i love AUTOZONE
theres probably 20k on the clutch......pedal doesnt seem to have changed....so im assuming line pressure is good and i know theres no air in the lines...i bled the lines when the clutch master was replaced not too long ago....the only thing thats making me think it could be the clutch is the throwout bearing problem and its an ebay clutch according to the previous owner
Forward gears huh....... did the shifter bend? When you shift into those gears the rod will travel towards the rear of the car. It may not be engaging all the way.
Vance @ 863-604-2139 for any questions
You did not tell us what you meant by "lost" up gears. Do you mean while driving and using the clutch, or are you saying you can't even get the gears while the car is parked with the engine turned off?
Call The number in my sig, I went to him when I was having clutch problems, hes great.
