iacv?
on
iacv?
bought an "obd1 b16" intake manifold to replace the 2000 si one that came with my swap (so i could use the IAT sensor in the runner) however the iacv mounting is differant. the lower bolt needs to be farther down and twards the passenger side. does anyone know what valve i need? it also appears that this manifold is JDM because it does not have the vacuum line for the purge solinoid on the back.
dirtier one is the 2000 SI one. see the extra bolt hole? thats where the stock SI one was mounted.
is this even an obd1 manifold? or is it obd0?
thanks
thanks
"Black people can't be racist" - Some black guy.
A question....if only one bolt holds the sensor in place in one case,
does it need more than one bolt in either case?-Bob
on
both of them use 2 bolts, just the older one uses 2 that are spaced farther apart, and it looks like the newer manifold could use either one.
texted you
