ls swap info
Old Jan 16, 2002 | 05:37 PM
charliehall's Avatar
does anyone know of good sites that have to do with sawping ls motors in the 5th gen civic besides hasport that tells me what i need axels how to rewire a ls harness to a cx one etc... thanks guys
charlie hall
Old Jan 16, 2002 | 09:44 PM
Joker's Avatar
Eat My Ass With a Spoon
you can try the honda hybrid page. and basicly read any b-series swap info into a civic and you will get a general idea for the swap and what will be needed. its all about research and the hunt for the knowledge good luck.
http://hybrid.honda-perf.org/index.html
This thread was brought to you by "Joker's ButtSeXxX" railing your sisters tarstar since 1992.
Old Jan 18, 2002 | 11:38 AM
i have the motor already its a 96 so its diff then the 95 also will a 95 1.8 tranny bolt up iknow it will but do you have to do any thing to make it work thanks
charlie hall
Old Jan 18, 2002 | 05:25 PM
specie's Avatar
The 96 up wiring harness is OBD2 while the 92-95 is OBD1. You can use the 95 tranny (that tranny is hydraullic; 92 up Civic are hydraullic so itll work without any work.)
You can use the 95 wiring harness ecu and distributor or you can do a OBD2 to OBD1 conversion or vise versa. Im not exactly sure if Im correct about the wiring since Im more of a 4th gen fan but I hope it helps.
Old Jan 19, 2002 | 09:09 AM
93sircivic's Avatar
If you have the 96 ls harness it should plug in with no trouble That way you can use the dist. and injectors from the 96 engine without having to purchase new ones. I dont think that there are any wiring differences that would affect anything since your not running vtec. Just use the 95 ls ecu since your ecu knows what sensors to look for it wont mind if there are extra sensors there.
late
Old Jan 19, 2002 | 06:17 PM
i have the ecu already its for a 99 i was told its the same as a 96 but how would i ever hook that up thanks
charlie hall
Old Jan 19, 2002 | 07:04 PM
letsrollagn's Avatar
BRT OVERKILL
You will need the 96+harness as for the wiring you will need to make the car have dual o2 sensors(OBD2) as opposed to OBD1 but if you use the harness you will have all the clips and connectors it will be easier that way. If you did want to use the existing 92-95 cx harness you would have to remove the 92-95 harness off of the engine and put it on the new ls engine. But this is more costly and you will need buy an OBD1 distributor and a few misc things cx is a pain but do-able I am almost done with my hatch b16a1 in a 93cxhb....
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Old Jan 22, 2002 | 09:42 AM
KJ's Avatar
KJ
bored at work
Easiest way:
Use the 96 motor with the 96 engine harness and just plug it into your car harness as already mentioned. Run a 94-95 ecu. A 92-93 ecu will work also but I believe it might be a little different as far as timing/fuel maps.
teg2gen
Nissan/Infiniti Tech
Mar 15, 2001 02:10 PM
webdog
Mar 9, 2001 01:50 PM
webdog
Feb 28, 2001 06:01 PM
99hatch-clint
Feb 22, 2001 11:16 AM
2000SE
Oct 11, 2000 04:54 AM
