Tie bar uninstall...
Old Jan 14, 2002 | 10:01 AM
AustinSi's Avatar
--Hebrews 13:2
How do I get this damn thing off my Si!! (Comptech rear tie)
Do not store up for yourselves treasures on earth, where moth and rust destroy, and where thieves break in and steal. But store up for yourselves treasures in heaven, where moth and rust do not destroy, and where thieves do not break in and steal. For where your treasure is, there your heart will be also.
--Matthew 6:19-21
Old Jan 14, 2002 | 12:51 PM
Bill's Avatar
Livin' in Seattle
Originally posted by "Someone"
Originally posted by Robster
lower or upper? I made a rear bad and put it on then when I went to install polly upper shock bushings I had a bitch getting it off the edge where the hole is was stuck on the thread of a bolt and I ended up having to cut the bitch off. Oh well I didnt do a good job making it I need to learn how to weld.
Robster
We need to get together sometime and shoot the shit about suspensions. When I checked out your car that day you shoulda shown me all your goodies. Bastard.
Hey AustinSi Im gonna assume youve got the upper tie bar. Just pop the trunk undo the nuts pull it off put the nuts back on.
Old Jan 14, 2002 | 09:40 PM
AustinSi's Avatar
--Hebrews 13:2
Its the lower tie/sway combo I got the sway off Taylor explained how to do the tie earlier thanks bro.
--Matthew 6:19-21
Old Jan 15, 2002 | 05:08 AM
Bill's Avatar
Livin' in Seattle
hmmmm its been about a year since Ive looked at a comptech setup so i may be missing something here but start with the d bracket endlinks the sway bar should come off now now just take off the lca bolts and the bolts that bolt into the subframe.
Robster
yup Robs got it right just uninstalled mine last week.
Old Jan 15, 2002 | 04:26 PM
AustinSi's Avatar
--Hebrews 13:2
I need to jack up the control arm to take the support off of the main bolt throught the tie bar
Thanks guys
-Austin-
--Matthew 6:19-21
Old Jan 16, 2002 | 12:12 PM
Bill's Avatar
Livin' in Seattle
Thanks guys
-Austin-
No you dont.
The only reason youd need to jack up the control arm is if you took out the bolt holding the arm to the hub.
All you need to do is undo the bolt place a wrench behind the bolt head and pull the bolt out with the wrench while turning the bolt with a ratchet. Simple.
