Quick Battery Re-Location Question
Old Apr 15, 2009 | 12:52 PM
da92nv's Avatar
...let's blaze!
Default Quick Battery Re-Location Question
This may sound like a dumb question but I just want to be sure.
I have everything i need to get my battery moved to the back in my DA. Once i route my wire from the trunk to the bay the connections are as follows:
+ on the battery to distribution block
distribution block to starter
distirbution blcok to fuse box
Ground to the chassis
I am just looking to get a confirmation on this....I have never done a relo...
thanx in advance
...TR's OldSkool DA Crew Member #00...
...TR's Oldskool DB Crew Member #02...
Old Apr 15, 2009 | 01:02 PM
freakasis's Avatar
its easy, just run a big wire from the pos terminal (or to everything on the pos terminal) to the back of the car, and a big ground wire to the chassis. make sure you get a good connection to the ground. good luck.
"Black people can't be racist" - Some black guy.
Old Apr 15, 2009 | 01:21 PM
da92nv's Avatar
...let's blaze!
what about the starter? I know the factory wire splits off to the fuse box and starter...then continues to the battery. I want to mimick that exactly.
I am using 4g wire for +/- prolly 8g from the black to the starter and fuse box. Am I thinkin along the right lines?
Im gonna attack this task in the morning
Old Apr 15, 2009 | 05:17 PM
custom240sx's Avatar
DC Crew Member #1
You are correct sir. Single run of 4ga from distribution block to battery in back. 8 ga to starter and fuse block from distribution block. Be sure to grab a nice 80 Amp fuse to put in line with that 4 ga wiring...wouldn't want that thing to ground out without a fuse. Also, I used 0 ga on my ground instead of 4...I wanted to be sure it had a good ground
Old Apr 15, 2009 | 05:41 PM
da92nv's Avatar
...let's blaze!
^ I have a nice piece of 0ga (clear) I can use for the ground. I also have a 120a fuse block im gonna use...
Old Apr 15, 2009 | 05:53 PM
DC Crew Member #1
You're good to go then. Make sure you bolt that battery down well, god forbid if you get in an accident and that sh*t isn't secure...
Old Apr 15, 2009 | 06:01 PM
da92nv's Avatar
...let's blaze!
im using my Optima Red Top and it is getting mounted to the floor with custom brackets til I find a box that I like...
Thanx for your help...Ill try and post pics when Im done
Old Apr 16, 2009 | 06:27 AM
da92nv's Avatar
...let's blaze!
damn...i need to get out and buy some smaller loop connectors. I don't have one small enough to fit into the fuse box. I guess I can run all the wire anyhow and get it ready...i'm not going anywhere anyway!
Old Apr 16, 2009 | 07:02 PM
DC Crew Member #1
If you need help let me know. I can swing by tomorrow and show you how to do it all.
Old Apr 16, 2009 | 08:13 PM
da92nv's Avatar
...let's blaze!
i think I can do it all, but and extra hand wouldnt hurt! hit me up...
