ARP connecting rod bolts?
Old Apr 12, 2009 | 08:28 PM
wolfenr1984's Avatar
Great White Hope
Question ARP connecting rod bolts?
Are they necessary on b18c connecting rods? I found these Lightning Motorsports - ARP Rod Bolts for 1.6-1.8L Acura & Honda 9mm - 208-6401 . How much stronger are they over stock ITR connecting rod bolts and do they carry any negative side effects upon installation once torqued?
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Apr 13, 2009 | 12:12 AM
While I cannot say how much stronger ARP is without a destruct test,
I don't know of anyone displeased with them. As a guess, your stock rods will let go before the ARP's do. Those ARP guys know what they are doing.
............if you run some serious turbo boost, it's cheaper to replace rods and bolts, than to rebuild a blown motor and use new ones the second time around.......-Bob
Old Apr 13, 2009 | 02:47 AM
rangcrx's Avatar
engine building &best
^with him,do it know so you dont have to later its a nice safty step in any motor...Arp rates there bolts around 148,000Psi as for stock 9mm honda rate there for 23 or 27,000Psi thats good enough for me
i love AUTOZONE
Old Apr 13, 2009 | 03:35 AM
Great White Hope
Ok, that makes sense but isn't there another step to installing them than just popping them in and torquing them down? Is there any machining required after installation?
Old Apr 13, 2009 | 05:51 AM
rangcrx's Avatar
If you have a c.clamp u can do it that way or just do it when install on 3 step tq down..some say u can bore the cap end out some not sure why I never have..
i love AUTOZONE
Old Apr 13, 2009 | 07:43 AM
Paulino's Avatar
Not harsh, just truthful
Highly recommend ARP hardware when engine building.
Old Apr 13, 2009 | 10:35 AM
Great White Hope
Do stock rod bolts look like the ARP rod bolts? I'm looking at the pictures of the ARP's and they look identical to my current bolts.
Old Apr 13, 2009 | 10:42 AM
Great White Hope
Also, I called up the machine shop where my motor currently is and they told me that when installing ARP rod bolts, the rod ends may get misshaped once they're installed and torqued, causing misalignment and future rod knocking. They recommend that I do purchase them but that they install them so that they can check the big rod end for misalignment once torqued.
Does this make sense? It does to me.
Old Apr 13, 2009 | 11:58 AM
hondachris1994's Avatar
hatchback1994
^^^I think they are trying to milk some more money out of u. I would let whoever is building your motor install them. Misalignment could happen with a stock rod bolt if your not careful
Old Apr 13, 2009 | 12:04 PM
Great White Hope
I'm building the motor.
It does make sense that they could cause the big ends to become misshaped. ARP suggests that they are torqued then checked for roundness, prior to being installed.
