ARP connecting rod bolts?
Old Apr 13, 2009 | 12:39 PM
rangcrx's Avatar
engine building &best
you will be fine the rod bolts are all cut the same way so this does not happen.i myself install them with a press and a lil solid plastic tube i made...when installing the arp bolts make sure the tilt cut side is on the outside you will be fine
i love AUTOZONE
Old Apr 13, 2009 | 03:19 PM
integra's Avatar
90% grind 10% sleep
have a machine shop install the bolts, its cheap and you wont have problems.
I have a set brand new but its only for 3 rod sets,you could call arp with the part number on the package and see how much 2 bolts and nuts would be. LMK if you want them.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Apr 13, 2009 | 04:08 PM
JoKiE crx4294's Avatar
popeye built!
This probably isnt the right way, but on my last motor i had stock ls rods on wiseco pistons and i just hammered out the old rod bolts and pressed in the new arp's by hand and then when i torqued them down, the bolts set in all the way and i never had a problem with the motor(400+whp)
Can't spell strength without tren
AAS...It's whats for dinner
Old Apr 13, 2009 | 05:38 PM
wolfenr1984's Avatar
Great White Hope
No thanks on the bolts, I just bought some a couple of hours ago.
And thanks for all the help, everyone. Rep has been given to those who I can give it to!
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
