lsvtec fuel stumble!!!
the problem is that when i start my car and drive away as soon as the rpms hit 2000 it seems like it hits a cut off and the idel drops back down to 1000 or when u leave the car in neutral and rev the motor it does the same thing but inder hard/moderate exceleration it wont do it for some reason/ also after the idel drops i do not have any throttle response unless i press the pedal down like and inch and then it surges forward
the car ran fine untill my friend and i corrected the timing issue and realized the IAC was never hooked up/ we corrected that also but ive had nothing but problems with it since
any advice or insight will be appreciated
so my lsvtec i think isnt getting the rite fuel pressure to the fuel rail and ive in stalled a new fuel pump/filter and siphon in the tank.also ive replaced the throttle cable and cable stay
also i thought that it mite be the tps so i bought a new one from omni power and intatlled it and the problem remains/ i also noticed i dont have a block breather on the back of my block could this be the problem
_thanks
_thanks
5TH GEN. CIVIC CREW MEMBER #26
:eg coupe b20z/gsr trans
Recently Iv had a real funny situation. Car ran great untill it tried to go into boost. Once it hit atmospheric pressure (0) the fuel pressure would go all over the place. We tried everything but, in the end the fuel line from fuel filter to rail was getting a pocket inside and would restrict the fuel.
If you feal it is a fuel issue I would get a gauge on it so you know what the fuel pressure is and then trouble shoot the car. It could be a bunch of things like plug wires rotor etc etc.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
thanks guys i also thought it might be the fpr but il get a gauge and see what kind of pressure i have (whats the useual psi for the fuel rail?)
ive got another ls complete motor but its in my other car i just bought and it needs to be rebuilt can t i take the breather off that block and put it on mine?
the breather on the block isnt going to make it stumble but, to answer your question yes you can swap it from other block. They are a little diff from pre 96 and post 96 if Im not mistaken
T & C Racing
FT Crew Mascot lol
T & C Racing
FT Crew Mascot lol
I was messin' with you. You seem to be missing that your problem only started when you connected the IAC. Why not start there? You also set your timing, but assuming you set it right, that would not cause the problem.
new development i recently ordered a new tps from omni power and set it right and the problem remains could they have sent me a faulty tps? what are the chances of that happening and also if i unhook the tps the car idels a little low and gets horrible mpg but the fuel srumble goes away????
