lsvtec fuel stumble!!!
Old Apr 9, 2009 | 09:35 AM
custom240sx's Avatar
DC Crew Member #1
I puttin in $20 saying that he contacts omni power telling them that he got a bad tps first and then changes out the clutch because it may be binding up at 2k rpm and keeping him from accelerating but when he floors it the insane power of the lsvtec overcomes the binding clutch and allows it to rev all the way up
Ok enough with being an ass...yes the TPS can do that and all you have to do is ohm it and make sure it is set correctly. My bet is that you didn't install it correctly. Also, check over timing again and have SOMEONE ELSE check it without you telling them what you got and compare your findings. I am saying it that way so you can rule out timing. And as for the IAC, you should make certain you have the right plug hooked up to it and that the IAC isn't bad. Maybe that is way it was unplugged in the first place.
And this is a shot in left field but if your running a tuned ecu maybe the tuner didn't realize the IAC was out of there and compensated for it in the maps? I dunno if that is possible but I'm just going to throw it out there.
Old Apr 9, 2009 | 04:47 PM
slicshoes's Avatar
i set the tps my sef at .45 ohms so thats set right. im going to go over the timing again 2mro and put another iac on from my other ls motor
as far as i know the p72 that im running isnt tuned yet
thanks for the smart ass comments too
5TH GEN. CIVIC CREW MEMBER #26
:eg coupe b20z/gsr trans
Old Apr 9, 2009 | 05:48 PM
PeteStop's Avatar
We can build your dream!
Originally Posted by slicshoes
new development i recently ordered a new tps from omni power and set it right and the problem remains could they have sent me a faulty tps? what are the chances of that happening and also if i unhook the tps the car idels a little low and gets horrible mpg but the fuel srumble goes away????
Call me for some tech help im sure we can solve ur problem!
Thanks,
Carter
PETE STOP
3991 Park Blvd
Pinellas Park, FL 33781
www.Petestopmotorco.com
PERFORMANCE, INSTALLATION,REPAIR,Nitrous fills, Mon-Fri 9-6 Sat 9-5
Complete Repair, Import,Domestic
Forced Induction, Bolt on, custom, alcohol, Nos
COMPLETE INTERIOR, Custom everything
Import tuning by, Carter Taliaferro
Domestic tuning by, Pete Stop- tuner of your choice.
If your not first your last!
727-541-3400
Old Apr 10, 2009 | 09:11 PM
slicshoes's Avatar
hey guys i pulled the complete stock throttle body off my other ls motor and the iac cleaned the hell out of them and hooked every thing back up the mid range idel problem is gone and the stumble also gone but it is now ideling between 2000 on initial start up and after u drive it for a while it goes down to 1500/1700 so thats the only problem for now everything else is solved thanks guy for the help and advice
Old Apr 12, 2009 | 05:41 AM
slicshoes's Avatar
problem solved thanks guys it was a bad throttle body gasket thats all
car runs great now all i need is to get my ecu tuned
