prelude running rich, suggestions
Old 03-31-2009, 04:27 AM
Prelude_!n_7h3_D!r7's Avatar
Default prelude running rich, suggestions
just installed new walbro 255 and fuel filter but now im running crazy rich
Old 03-31-2009, 05:49 AM
smokes weed...everyday.
95gainfla's Avatar
lemme guess...
youre not tuned for the 255 pump?
I <3 RooR!!!!!!
Old 03-31-2009, 05:51 AM
yup
running so rich that its cooling the engine
the liquid gasoiline changes to a vapor but doesn't burn absorbing heat in the phase change
Old 03-31-2009, 06:45 AM
Four Door Mafia
EconoBox's Avatar
You don't have to tune for the fuel pump you just need an adjustable pressure regulator to turn it back down to factory pressure. Putting in a better pump does not change the flow rating on the injectors but the higher pressure from a more powerful pump pushes more fuel through them. If you put it back down to stock fuel pressure (right around 43psi with the vacuum unhooked) it should fix your problem.
If that doesn't help out it sounds like you could have an injector stuck open. Usually installing a Walbro doesn't cause a problem as bad as yours.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old 03-31-2009, 10:20 AM
thx
rep +1
Old 03-31-2009, 11:10 AM
95gainfla's Avatar
yea, adjustable fpr would work. thats what i was leaning towards(i didnt mean like, dyno tune, i just meant you threw the pump in and thats it, no adjusting anything)
I <3 RooR!!!!!!
Old 03-31-2009, 12:36 PM
hatchback1994
hondachris1994's Avatar
Putting that new fuel pump isnt going to make your stock FPR send more psi. The new fuel pump isnt gonna make it jump past the rated psi of the stock FPR
Old 03-31-2009, 12:45 PM
freakasis's Avatar
ive installed these pumps on several differant cars and have never had a problem with the stock regulator. i dont think the flow rate of the fuel will affect the pressure maintained by the regulator. its just a spring valve that opens at a certain pressure to let the fuel run off back into the tank...so unless your return line is bent/clogged somewhere, you shouldnt be having this problem.
"Black people can't be racist" - Some black guy.
