?s involving toda cams.
i just came home from buying toda spec b cams i kinda just went off and bought them cause i was looking for cams and everyone told me it was a good deal. So now i do my research on them on the web site it said that i had to use there valvesprings. is this true? oh buy the way the valvesprings are some $$$ and on top of that because there egg shaped id have to buy there retainers to. i was told by the person i bought them from that it would be hard to get the car to idle right..is this because the cams are lopey or because of my ecu(first gen b16 black/green pr3 ecu)? what would be the best ecu program with such agressive cams? iam sure ill have more questions later thanx for da help.
-B.J.F-
-B.J.F-
Guest
Posts: n/a
im running spec b and using portflow springs and retainers.ive had them for almost a year with no problem taking them up to 9500 rpm.you will need a custom chipped ecu which throws fuel and timing to get the car to idle.i currently have a yoshio chipped p72.i forgot his web site but heres a place who carries the program www.godspeed.hack.net
Guest
Posts: n/a
bad street cam... terrible idle should have just gotin (hehe) the type r cams you wanted in the first place... more midrange power... yes thats right... MORE midrange power from the factory type r cams... and half the cost. Toda B spec cams are a full road racing cam. If you want to float a valve go ahead and use your stock springs... why not get the toda valvetrain they designed for their cams? or use a combo of the toda springs with crower retainers (5.5 grams lightest ive seen)
Guest
Posts: n/a
1 h4v3 3><p3|213|\|c3 1|\| 7u|\|1|\|g 7h353 c4m5. 70 g37 7h3 m057 0u7 0f 7h3m c0|\|51d3|2 4 H0|\|d474 upg|24d3 4|\|d l4|2g3|2 1|\|j3c70|25 f0|2 y0u|2 c4|2. 1 c4|\| 7u|\|3 7h3m b07h. 1f y0u d0 g37 4 H0|\|d474 upg|24d3 1 c4|\| m4k3 17 1dl3 45 \^/3ll 45 570ck. 7h353 4|23|\|7 4 c0ld 41|2 1|\|74k3 7h3y |23qu1|23 50m3 53|210u5 7u|\|1|\|g 70 |234p 7h31|2 |23\^/4|2d5.
1v3 u53d 17|2 0u73|25 \^/17h P0|27fl0\^/ 1|\||\|3|25 \^/17h |\|0 p|20bl3m5 47 4ll. 1 c4|\| 4l50 |23c0mm3|\|d ju57 4b0u7 4|\|y |23741|\|3|2 0|\| 7h3 m4|2k37. 4dju574bl3 c4m g34|25 4|23 4 MU57. M0|23 qu35710|\|5? 3m41l m3.
-B.J.F-
-B.J.F-
Also Id consider getting an aftermarket timing belt especially if you use the toda springs.
Gracie Barra Clearwater
Guest
Posts: n/a
[qu073][1]0|21g1|\|4lly p0573d by "50m30|\|3"[/1]
[1]0|21g1|\|4lly p0573d by KJ [/1]
4l50 1d c0|\|51d3|2 g3771|\|g 4|\| 4f73|2m4|2k37 71m1|\|g b3l7 35p3c14lly 1f y0u u53 7h3 70d4 5p|21|\|g5.[/qu073]
??:c0|\|fu53d
? 1 h4v3 |\|3v3|2 h34|2d 0f 7h15 b3f0|23....c4|23 70 3><pl41|\|?
??:c0|\|fu53d
well the timing belt has to pull the cams and when the spring pressure cam lift and ramp angle are dramaticaly changed this increases the stress on the timing belt. There was a thread on this in the type r forum on honda-tech a while ago and a bunch of people were wondering why they were breaking timing belts with newly installed cams in particular toda B and Cs with toda valve springs. Just something that I think is worth looking into. I also think if a stock t-belt is used it would be alot safer to use the type r/portflow spring combo after seeing a chart of spring pressures for the different types of springs out there.
i bought a crapload of new gaskets seals hoses and all new belts from the honda dealer for my motor....i diddent know there was such thing as an aftermarket timming belt.
-B.J.F-
-B.J.F-
