transmission question
Old Jan 6, 2002 | 09:54 AM
RicerX's Avatar
Icy Hot Stuntin
Im changing an axle on my b16al CRX and when I pulled the axle out no tranny fluid spilled out. Is this normal? I often here of people making a mess when pulling the axle out.
Am I low on tranny oil? How can I tell?
Can you ever have too much tranny oil?
Thanks
Mike.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Old Jan 6, 2002 | 10:35 AM
Bill's Avatar
Livin' in Seattle
Ya youre probably a bit low on tranny fluid.
Look at the side of your tranny case and youll notice two fairly large bolts. One accepts a 3/8 drive ratchet and is used for draining the case. The other accepts a 15mm or 17mm socket (could be wrong just thinking off top of my head) and is used for filling and checking fluid levels. Basically you just take the upper bolt off and stick your finger in there to see if the fluid is up to the hole. If not fill er up. Might also want to take a mirror and check it out and see what type of state the fluid is in.
Old Jan 6, 2002 | 10:43 AM
2qk4u's Avatar
if u do end up changing the fluid i would recomend going to hondaland for tranny fluid. its supposed to be the best for ur car. some dude told me to always get honda oil filter honda radiator fluid and tranny fluid to. dont know why but i suppose honda knows wassup.
Old Jan 6, 2002 | 10:46 AM
b16a2pwr's Avatar
ALLJDM
honda is the stuff. Its always what I throw i my car. Anyway Bill i think that the Tranny fluid takes a 1/4 inch drive to open it up not the 3/8 but I bet that youre right since you are the man!
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Jan 6, 2002 | 03:04 PM
KJ's Avatar
KJ
bored at work
Its a 3/8 drive and a 17mm. With the car level just fill it up until fluid is coming back out of the fill hole. Takes about two and a half quarts for b series trannys and at $4-5(from Honda) a bottle it is a bit pricey but worth it.
webdog
Mar 9, 2001 01:50 PM
92CavRS
Mar 9, 2001 05:41 AM
ryuujin
Mar 8, 2001 04:25 PM
hybridEG
Feb 12, 2001 09:23 AM
90teggs
Feb 5, 2001 04:04 PM
