is my Distributor bad ?
Old Mar 20, 2009 | 04:43 AM
sprjit22's Avatar
Rick James bitch
is both of your grounds hook up? One on valve cover other on tranny? I have seen the ground missing and cause this issue.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Mar 20, 2009 | 05:25 AM
extatic002's Avatar
is an asshole
undo the clip thing from the distributer that hooks to the head and then hook it back up..make sure its in all the way
Just a thought cause same thing happend to my cousin when we took his head off..
Originally Posted by The Kyle
I quit every time I run out.
Then I quit quitting every time I get more.
Originally Posted by Clawhammer
As a general rule of thumb; if I can't fix it with a hammer it must be an electrical problem.
Old Mar 20, 2009 | 07:01 AM
jboyzTeg's Avatar
Damn .... thnx for your info .... I just checked both my VC and tranny's ground and both are good .... I also did disconect the clip and re-connected them and still nothing ..... now I'm just puzzled lol
Old Mar 20, 2009 | 07:05 AM
YBlegal's Avatar
Broke not Built
borrow a dizzy from someone who has a known working one. if that fixes it, then you know you need a new one.
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Mar 20, 2009 | 07:13 AM
sprayedtegra's Avatar
Fucking HONDA enthusiast
I've purchased a new coil in the past that was bad!
You can check your distributor with a digital multi meter by going from the blue/yellow to blue/green, orange to white, and orange/blue to white/blue wires at your dizzy connector. your looking for i believe 340ohms to 700ohms. If you see 0 you have a short internaly. If over 700 there is an open. This would mean one of the sensors in your dizzy is bad.
However you should see a cel code for tdc, crank position, or cylinder sensor.
Just a suggestion for something else to check!
Good luck!
TR "Old Skool EF" Member #093
Old Mar 20, 2009 | 09:17 AM
jboyzTeg's Avatar
thnx ! i will try this asap .......
Old Mar 22, 2009 | 05:27 AM
  #17 (permalink)
jboyzTeg's Avatar
someone help me ! i need someone to come out and look at it ! anyone ?!
Old Mar 22, 2009 | 07:36 AM
  #18 (permalink)
hondachris1994's Avatar
hatchback1994
+2 this will narrow the dizzy option out
Old Mar 23, 2009 | 12:25 PM
  #19 (permalink)
jboyzTeg's Avatar
I put a working dizzy in and nothing still no spark ! C'mon someone help me plz ! I need this car 2 be running because its my DD
Old Mar 23, 2009 | 12:34 PM
  #20 (permalink)
YBlegal's Avatar
Broke not Built
try a different ECU yet? check your wiring connections? check your timing belt? if the timing belt is broke then the dizzy wont turn, there for no spark....
i didnt feel like re-reading everything so if these options have been tried already please disregard.
