HONDA Guru's needed please
the ecu is a p28. believe its chipped by vega. It has oil and when i start up the car it will hit vtec a few times then it will just stop popping. I need to turn off the car and start it again and it will pop again.
My speedo does not work. I do not know the reason tho.
It does have a cel just have not checked it yet. sorry
TR 5th Gen Civic CREW Member # 04
well obviously you should check that first before comin on the internet wondering..The CEL is gonna point you in the right direction before TR will
Just read the cels and it came up as 1,9,17. Oxygen content, cylinder 1 piston, and speed sensor. So im thinking the speed sensor solves the vtec issue. Wat can be wrong with the cylinder 1 piston? Is that something a compression check can evaluate?
9 CYP - cylinder sensor
U have to replace your distributor that sensor is built in the distributor
replace your O2 sensor
check wires goin to sensor/replace VSS
fix those 3 things and u should b good to go
