Help me REBUILD my Ls/Vtec-Turbo
the rod bolts are 27ft/lbs i believe if they are the 3/8 bolt. use moly lube on all the threads ie...headtuds, rod bolts, main studs.
Can't spell strength without tren
AAS...It's whats for dinner
stock ls main bolts will not work with a girdle you need either gsr or d16 SOHC main bolts...as for tq specs i myself do 28lb on rods 38 on mains
i love AUTOZONE
i love AUTOZONE
correctly clocking and gaping the piston rings http://www.theoldone.com/articles/en...istonfacts.htm
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Non-VTEC:$20-up
VTEC:$40-up
Lightning Motorsports - Golden Eagle B16-B18-B20 Main Girdle Kit ARP -
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Non-VTEC:$20-up
VTEC:$40-up
you have to use the 234 main caps from the the girdle stock ls mains will not work with it..but no honeing is not need unless for some reason the crank does not spin freely after it is tightened down,make sure all caps are arrowed to the oil pump staring with 1 being closest to the oil pump
i love AUTOZONE
i love AUTOZONE
^ k thanks, i will be starting the work soon. between my son and my medical issues i haven't had time. i will be posting pics in a bit to show you guys my work area and the work i do as i do it...
its coming...
its coming...
this is a no no. use either ARP lube, or 10w30 engine oil. ARP will have torque specs for both. different torque specs for different lube. hope this helps.
