vtec problem
Old Mar 8, 2009 | 01:31 PM
deawynejr06's Avatar
Default vtec problem
o0k...
i got a b18c1 swap in a 94 eg hatch
....and my vtec doesnt work
i have all the wiring right
i have no check engine light but vtec doesnt work
today i was on the high way and just wanted to push my car a little
then check engine light comes on
when i get home i read the code....which was Code 22 V-TEC pressure
solenoid
i switched it 3 times now and it keeps doing this
i turn off my car turn it on and no cel
i hit it again and the code comes on again what might be the problem
IM IN NEED OF VTEC
Old Mar 8, 2009 | 01:54 PM
custom240sx's Avatar
DC Crew Member #1
If the switch is going bad, check for some type of electrical issue. Have you put the solenoid on another car to see if it is actually that?
Old Mar 8, 2009 | 03:19 PM
Default ....
i got the oil pressure switch from a motor that was working fine poped v tec could it be my oil pump but the thing is my motor runs fine just no vtec
Old Mar 8, 2009 | 05:19 PM
hondachris1994's Avatar
hatchback1994
check your oil, if your oil isnt at the proper level vtec wont work and that CEL will come on. If it did indeed come on cause of low oil, u were a good quart and a half low on oil, I know this by expierence
Old Mar 8, 2009 | 05:49 PM
Nandosol's Avatar
Garage Slut
It could be your vtec wiring/ground. Is the car a GSR? or an LS/GS/RS If its not a gsr it will not have vtec wiring, unless whoever did the swap wired it. You should check to see if thats there first. Look at the solenoid and follow the wiring. If not check to see that you have a gsr ecu. Then do the wiring its easy.
Old Mar 8, 2009 | 06:36 PM
BABILLARACING's Avatar
change the ecu , that happened to me a while back
Old Mar 8, 2009 | 07:10 PM
boostedcoupe's Avatar
try the ecu, also mine wasnt crossing over into vtec because i didnt have enough oil pressure. check and make sure that you have at least 55psi of oil pressure or vtec will not enguage.
Old Mar 8, 2009 | 08:49 PM
Nandosol's Avatar
Garage Slut
I would check all the other things before doing this. Just because he is throwing a vtec pressure switch code I would not assume the ecu is bad.
You can bring the car over and Ill take a look at your vtec wiring if you want.
Old Mar 9, 2009 | 06:44 AM
sprjit22's Avatar
Rick James bitch
Have someone look at it that knows about the wireing. Make sure you have a good connection also.
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Mar 11, 2009 | 04:29 PM
ok the way i wired it was i cut the pressure switch and grounded the blk wire and wired the BLU/BLK to D6, & vtec selinoid GRN/YEL to A4 a its a obd2 b18c1 in a 94 eg hatch im using a obd2 gsr engine harness & im using a p28 am i doing somthing wrong lmk
