vtec problem
Old Mar 11, 2009 | 04:37 PM
Thatguysstuff's Avatar
Hey its that guy!!
obd2 harness with a obd1 p28.....??
Hmm.... do you have a jumper harness??
is your speedo working??
Old Mar 11, 2009 | 04:48 PM
deawynejr06's Avatar
Default ....
well the dizzy and injectors plugs are obd2 and were the harness connects to the harness comeing from the car its self (tower plugs) their is a extra plug that doesnt have nothing to connect to
Old Mar 11, 2009 | 04:50 PM
Default ....
and yes my speedo is working
Old Mar 11, 2009 | 04:52 PM
Gustavo's Avatar
EKillers, fast but humble
try bypassing the pressure switch here are the instruction http://www.phearable.net/tech/wiring/vtpsbypass.gif I have a gsr on a eg wire just like yours and is fine.
Old Mar 11, 2009 | 05:07 PM
Default ....
but other then that do i have the wiring right
Old Mar 11, 2009 | 05:26 PM
Gustavo's Avatar
yup,bypass it check if it works, if not check the ecu
Old Mar 11, 2009 | 06:47 PM
  #17 (permalink)
Kung.'s Avatar
OHH NOES!!1
vtaks no working sucks!! LOL!
Old Mar 12, 2009 | 08:28 AM
  #18 (permalink)
Nandosol's Avatar
Garage Slut
Have someone look at it dude. I still dont know how you expect someone to know how your wiring looks by the internet. With no pics, and no wiring diagram.
Old Mar 13, 2009 | 04:20 PM
  #19 (permalink)
EgAllDay03's Avatar
i by passed it but no vtec my wiring is good i took it to someone they did it i re wired it my self then i went on line to make sure thats how you do it and it is correct what else could not 'make your vtec work......oil, cams, ect.????????
Old Mar 13, 2009 | 04:59 PM
  #20 (permalink)
Nandosol's Avatar
Garage Slut
Low oil pressure, but you said your vtec press switch code comes on. So its either bad wiring, bad pressure switch, solenoid, or ecu.
