rev limit about 6000 after spending time at 7000 r
Old Dec 25, 2001 | 05:48 AM
Rideit's Avatar
after running at high rpm for a few moments the computer seems to cut the rev limiter to 6000. i shut the car off and restart and it goes away till the motor spends a little time at 7000 or so. 99 civic si with boost. the map is not seeing any boost either
'99 turbo si
13.34@103 on slicks 60' 2.01
13.48@106 on streets 60' 2.109
Old Dec 25, 2001 | 10:53 AM
Rideit's Avatar
oil level is full. i am going to put a oil guage in it to see if it drops while at high rpms. but any other suggestions?
'99 turbo si
Old Dec 27, 2001 | 06:59 PM
Rideit's Avatar
turns out that when SFP did the tuning they switched the vtec wires on the vafc near the comp. i finally was able to get the 22 code. so i pulled the kick panel off and they removed the purple and pink wires..now it works fine.. John i was suppose to meet Frank over in tampa but i think i missed him. i need to set up a time with you to get my shit tuned again.
'99 turbo si
Old Dec 28, 2001 | 02:57 AM
Rideit's Avatar
yes removed the pink and purple from the green/yellow.
'99 turbo si
