cv axle help on 92 accord
Old Mar 2, 2009 | 06:27 AM
crxskater25's Avatar
Default cv axle help on 92 accord
passenger side cv axle will not go into hub i greased them already and still won't go in how can i fix this
08 cr 85 big wheel-traded
91 ef hatch w/dc front end-traded
91 ef hatch si-traded
90 ef sedan ex/si 5spd-traded
87 k-5 blazer-traded
93 supercharged buick park ave. auto-scrapped
98 civic coupe hx/ex 5spd-traded
91 ef sedan lx auto converted to 5spd-sold
92 accord lx auto-traded
87 mazda b2000 5spd-sold
86 f-150 5spd-sold
84 k-5 blazer-sold
88 crx with gsr mildly built-traded
87 camaro 350 auto-traded
87 f-150 5spd 4x4-scrapped
92 eg fo-do 5spd-sold
97 chevy 1500 5speed, sas soon to come-dd
Old Mar 2, 2009 | 07:28 AM
Nandosol's Avatar
Garage Slut
Is it the same axle you took out? Make sure to push it in by the little hub that goes in the hole and not by the axle itself. Make sure the splines are aligned as well. If its the same axle it should slide in with a little nudge. You could use a rubber mallot to tap it in a lil bit. Make sure youre real careful with it
Old Mar 2, 2009 | 07:44 AM
hondachris1994's Avatar
hatchback1994
^^^+1 that thing should pop rt back in, just make sure u match it up with the old one, cause sometimes the auto parts store will give u the incorrect 1 if your not careful
Old Mar 2, 2009 | 09:28 AM
yea but the old one won't fit in either
86 f-150 5spd-sold
84 k-5 blazer-sold
Old Mar 2, 2009 | 02:11 PM
Nandosol's Avatar
Garage Slut
Maybe you have it backwards. Flip it around. The cvjoint should be closer to the hub.
Old Mar 2, 2009 | 08:20 PM
quietflight6787's Avatar
its all about the splines y0 lol get it pretty mch lined up and while push it in a little try to roate a tiny bit till it lines up and slides in,
Old Mar 2, 2009 | 08:23 PM
StreetBlitz's Avatar
B Tuned CRX
Rubber hammer FTW
