Hestitation before 3k rpms? (Except @ WOT)
Had the same problem with mine... Mine has a brand new dizzy on it...
ended up changing the plugs with some NGK iridiums no I have no problems with it...
check the gap on your plugs... the kid that put mine together before i got it had the plugs all gapped wrong...
have you checked for vac leaks? if not check the vac that runs to the fpr my hatch did somthing like this and it was that vac. if not take it to a mechanic that has a vac machine and have it smoked.
