Hestitation before 3k rpms? (Except @ WOT)
if its the ignitor his tach will bounce around. it could be a coil starting to go tho. i would replace cap rotor n wires for shits just to see. cant hurt.
i had this problem done to me before and it was the ignitor going bad, the rpms does not necessarily need to jump, mine didn't jump until one day my car died
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
Performance Inc.
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Non-VTEC:$20-up
VTEC:$40-up
^I'm not running any cam gears or any modifications, its completely stock..I will have to get a light and time it tho. I changed the belt before installing it, but it runs too good to be off a full tooth.
It only studders at a constant throttle under 3k. If you give it anymore than 1/8th throttle it accels fine.
This is a weird issue.
I forgot to mention its throwing code 41 (o2 heater circuit)
Any ideas how to fix that? I have replaced the o2 with a new Denso, still same code and same studder.
Unfortunately jail. On the subject of the motor...my hatch had a similiar problem and it turned out to be something in the dizzy. When are you gonna slap that b-tech head on there? I can't wait to see a 2.0ltr b-tech mange!
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
