Need help removing tranny B series cable
Hello i recently bought a da9 with a bad tranny and just came across a good one and was wonddering if anyone can give me a writeup or happen to know a thread with pictures or somthing.Thankyou,Grayson
If ANYONE NEEDS ANYTHING TOWED / MOVED IN THE TAMPA AREA PM ME ,ROLLBACK ON THE READY CHEAP!
its pretty simple on that i hope someone can find you what you need,just make sure you check your clutch disc first when you pull the old one to make sure it fits the new tranny b4 you try to force it in
i love AUTOZONE
i love AUTOZONE
it will match the tranny is a 91 and the clutch disc is a 91
,Yea it seems to be a fairly simple swap i just know theres a few headaches in there and knowing about them ahead of time is nice
change the rear main seal while your in there. its like $9 and well woeth not having to take the trans back off in 2 weeks.
BTW hondahookup.com has oem service manuals, which will have a step by step with torque specs and pictures.
"Black people can't be racist" - Some black guy.
^if he does that he might just change the clutc to,wait what is all wrong with the transmission in the car now?
i love AUTOZONE
i love AUTOZONE
has a hole in the bottom...
.Well heres the issue,Time.Im moving my car tomarow into a friend of mines garage and only have 6 days to do it.Which is plenty of time unless i run into any bumps.I was told the car has a new clutch but well see when we get in there .I hope its got some life to it
Well start with removing the axles first then undo the battery and remove the start then staret undoing all the large 17mm bolts. Then undo the shifter and cable then motor mounts should be pretty good
i love AUTOZONE
i love AUTOZONE
