Need help removing tranny B series cable
Awesome thanks guys i surley shot ya felas some pm's.The car is in the garage and on jackstands battery has been out and itook the axles out about an hour ago..I have taken the dist. off and had to cut the wires..
Plugs are a little dryrotted it looks like youd have to take it off to get at a few of those 17mm bolts.Now the next thing There are bits of the wiring harness around the tranny that seem to be,They haved to be removed for the tranny to slide out.?
If ANYONE NEEDS ANYTHING TOWED / MOVED IN THE TAMPA AREA PM ME ,ROLLBACK ON THE READY CHEAP!
be sure to inspect all of the dowels before putting it in there. to make sure that you dont have dowels in the block and the trans and to make sure theyre not fucked up.
"Black people can't be racist" - Some black guy.
Ok well slow moving BUT Shes about ready to come out I have 2 mounts off and most of the bellhousing bolts off and what is holding me up is the main shift rod,Not the extened.I need that punch to get that pin out...
anyone wanna give me a hand? I also gotta do just a tiny bit of wiring
.anyone wanna give me a hand? I also gotta do just a tiny bit of wiring
it being your first time just remove the shift knob out your car jack the car up alil more and undo the 2 12mm bolts holding up the whole shift just remove the whole thing with the transmission and take it off when you get the whole thing out
i love AUTOZONE
i love AUTOZONE
yup. do that...then you can turn the trans over and pound that bitch out real quick....i used a 1/2" battery terminal bolt from advance.
