What size injectors so get for fully built Ls-Vtec
Old Jan 2, 2009 | 11:12 AM
B16delsol's Avatar
Default What size injectors so get for fully built Ls-Vtec
I have a fully built high compression LsVtec motor. I'm running 12.5:1 pistons and I have a built head with Tuner Stg. III's and I wanted to know what's the biggest injectors I should get and what's the lowest I should get? Many people's info. is great to get an average decision for me.
Old Jan 2, 2009 | 11:44 AM
Jap's Avatar
Jap
VTEC Out
310cc should do the job just fine
Hondata saves lives
Old Jan 2, 2009 | 01:15 PM
mtber's Avatar
Old Jan 2, 2009 | 04:24 PM
sprjit22's Avatar
Rick James bitch
they both know their shit.^^^^^
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Jan 3, 2009 | 09:27 AM
B16delsol's Avatar
True, but that's not much higher then stock? So would 400cc be too high? It's going to be tuned and everything. Also a lot of spray
Old Jan 3, 2009 | 01:59 PM
mtber's Avatar
If your going to spray, I would recommend a dry nitrous kit with a set of 440cc injectors.
Old Jan 3, 2009 | 04:09 PM
B16delsol's Avatar
^Why not wet? I always hear it's the safest... I'm not going to be spraying all the time. I just want a daily that's going to be reliable and that can track it on the weekend and spray on it. I figured wet was the best and I can use my MSD to retard the timing when I spray so it's pretty safe?
Old Jan 3, 2009 | 04:18 PM
FrodoGT's Avatar
Found the Vtec switch.
He said dry because your ecu will add the fuel when you tune for it. To do that though you would need larger injectors, hence the 440. Just make sure your tuner does a set of nitrous tuning pulls to get it right. You dont want to just be spraying off your NA tune with a dry shot.
TR Old Skool EF Crew #24
Old Jan 3, 2009 | 06:08 PM
mtber's Avatar
You said it
Old Jan 4, 2009 | 08:25 PM
B16delsol's Avatar
You guys don't get it. I'm not like other people that spray on their motor day in and out. I will prolly spray on this motor and hand full of times a month. It will only be for back up. I will be wanting to run all motor. I just want to be able to spray if I have to...
