pistons
Wiseco...or through Larry (Endyn) do make 81.5mm pistons. I think the overbore pistons prices are the same. Can get the Endyn through Mike K for $530.
Update on the block: It was only one cyclinder that was worn to that degree. I think they were able to save it though. So time to build the motor up.
The mic on the crankshaft indicated stock specs. What bearings should I ask for when I call up Acura? Do I just ask for stock?
Thanks again for all the replys.
Guest
Posts: n/a
when ordering bearings you need to look at the block and the crank for the corresponding codes for the main and rod bearings.... im guessing your using the stock ls rods so just get a manual (haynes manual from discount auto for $11 works fine) and check the factory codes for the color bearings you need. The manual will explain exactly how to do it. If you decided to use endyn pistons and the eagle rods eagle rods are sized for a #3 bearing...
Guest
Posts: n/a
[qu073][1]0|21g1|\|4lly p0573d by "50m30|\|3"[/1]
[1]0|21g1|\|4lly p0573d by j99jm [/1]
4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..4|\|d pl4571g4g3 70 ch3ck cl34|24|\|c35..[/qu073]
Guest
Posts: n/a
Originally posted by "Someone"
Quote:
Originally posted by j99jm
and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..and plastigage to check clearances..
