injectors from other car that fit in my 95 civic
does anyone know of any direct hook no mods or light mod. injectors i can put in my turbo civic 95 - i'm looking for saturated
Buy some saturated precision turbo 440cc injectors brand new for around $210 and call it a day.
you can run some dsm 450 blue tops not to hard to instill just the resistor box is a littel tough...
Built By:Mike Carpenter @ Overdose Performance in Ocala,Fl...
Tuned By: Tony Gannon @ Hp Performance
hp~5!! trq-4!!
doing work!!!!!!
hp~5!! trq-4!!
doing work!!!!!!
Your injectors don't make your car go into limp mode.
Not properly having everything wired properly, having a bad engine computer or sensors will cause these kinds of issues.
What injectors are you running now?
What engine management are you running ?
i put the the turbo on and i still have stock injectors i took an easy for day or to then i got on from 1-3 gear after that instant limp mode wont go over 3k rpms hit rev litter at 3k wtf, i have a chipped p28 but don't have a new chip accounting for the turbo yet and i always use Phearable.net for chips, i filled out the order form for a new chip from those guys the day i installed the turbo it should be here tomorrow, I HOPE IT MAKES A DEFERENCE if it doesn't i'm going to take it to the shop to either have it tuned get a new map senser or have the codes deleted or fork out the dough for the new injectors
You need to communicate better so we can help you.
Do you know what map is on that chip?
From what it sounds its not like you bought a complete turbo kit that came with a map, but you pieced it together. That p28 could have a map for anything on it by now(Custom tune, base gsr/h22/type R maps). If you have everything connected right on your kit (oil lines, seals, intercooler(if youre running one)no boost leaks). I would not drive your car until you can afford to have someone burn you a basemap to start off with. That will run really rich, but it will get you by until you get a tune(All engines are different and will behave differently under boost). Do you have any CEL's? That is the first question someone asked you on this post and you still haven't answered it.
i have a cel on now( checked one of the codes and i think it was acceleration sensor or something like that) and the rev limit is now 3k thats the kit came with no map and the chip in the ecu was setup for the car before the turbo, that chip was burn for just my plain mini me set up(intake manifold exhaust, vtec...) i bought the kit used and put it together myself, its a t3/t4 .50, i didn't get new injectors or map sensor, i thought saying the car was in limp mode would mean the car has a cel on sorry about that
get bigger injectors. You can find some dsm 450cc for like 50 bucs around here and get it tuned asap. Stop going into boost unless you wanna be rebuilding soon.
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
