How To Port Match ???????
Old Nov 17, 2008 | 04:44 AM
a_g_ee_1985's Avatar
Unhappy How To Port Match ???????
I have a 70mm T/B and a stock type R intake manifold....and the problem is that my T/B has a bigger hole than the intake manifold.....how can i port match it myself.... or do you guys know any body that do it... please help
Old Nov 17, 2008 | 07:02 AM
LShatch98's Avatar
i love making you mad <3
maxbore.com
Proven Power for all your go fast needs
Old Nov 17, 2008 | 07:42 AM
Old Renegade's Avatar
Cool Runnings
what type of application is this going on? all motor or turbo? if all motor 70mm is too big.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
Old Nov 17, 2008 | 09:13 AM
chi town brat's Avatar
! Ne shab'rud'ni !
if you haven't done it before then i wouldn't suggest making it your first project
the way I have seen it done is to mark the outline of the bore needed on the part being ported by using a gasket or making a paper gasket
I can def back up maxbore.com as I have known the owner and his work for many years
Old Nov 17, 2008 | 09:55 AM
CBURKE's Avatar
Has to many projects
Just use the gasket and trace it with a marker. Grind it away untill you hit the line you made or all the marker is gone.
Cburke.industries.
Custom suspension bars, metal fabrication.
Old Nov 17, 2008 | 10:04 AM
Paulino's Avatar
Not harsh, just truthful
+2 If you don't trust yourself with tools send it to Maxbore.com throttle body boring service pricing remains at $100 for Honda throttle bodies as stated in the website.
Old Nov 17, 2008 | 10:13 AM
Jun_Tuning's Avatar
VTEChnician
to port match the intake manifold to the throttle body install the throttle body each screw twist twice (it will stay loose) open the throttle body and mark the whole circle of the throttle body with a permanent marker and there u go u can start grinding
HYBRIDWORKS
Performance Inc.
Repair shop / E-Tailer
"TR Member Discounts Available"
About Us
[/SIZE]
TR "Old Skool EF" Crew - Member #126
We Buy OBD1 Honda ECU's
Non-VTEC:$20-up
VTEC:$40-up
ECU'S WE BUY: P28, P06, P72, P75
Old Nov 17, 2008 | 10:14 AM
Jun_Tuning's Avatar
VTEChnician
sometimes the gasket isn't the same size
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Old Nov 17, 2008 | 10:18 AM
Jun_Tuning's Avatar
VTEChnician
70mm isn't to big for all motor, I use 70mm in all my all motor apps, I do not recommend it for a stock cylinder head unless your spraying
HYBRIDWORKS
Performance Inc.
About Us
[/SIZE]
Non-VTEC:$20-up
VTEC:$40-up
Old Nov 17, 2008 | 10:25 AM
sleepinsol's Avatar
starting over
+1 thats how i would do it. not all gaskets are the same. 70mm for all motor would give top end power at the sacrifice of low end. so pick what you want and go from there. IMO its over kill unless youve got huge cams, large ports, and a big bore to move all the air.
