Choosing Pistons?
may want to use a little over bore piston wich can be had from honda.
.25 to make sure cylinders are perfecly round.
and yes your goal numbers can be attained from oem parts, speaking from 1st hand experience
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
+2 on going .25 over
Going .25 over for the work of doing that how much power would I get instead of going standard? Not sure if it's worth the cost.
DC CREW MEMBER #18
DC CREW MEMBER #18
if no N20 go 82mm then wisco or eBay Motors: ACURA INTEGRA TYPE-R VTEC 82.00mm PISTON RING KIT B18C5 (item 180297542867 end time Dec-07-08 14:34:24 PST) are great sets
i love AUTOZONE
i love AUTOZONE
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
Going .25 over is not for power, its to ensure you have completely true cylinder walls..... It does not cost more for the pistons/rings that are .25 over bore.
Oh okay I see I thought maybe you would have to bore out or hone the block to put .25 over size pistons in. If not I can see now that it would be better.
DC CREW MEMBER #18
DC CREW MEMBER #18
Do your self a huge favor. Fork out the money to buy a Helms manual for an integra (gsr & ls). Then study the engine building portion like its a bible.
i think the jdm b16 pistons will have a lot of compression in that block check this link out this is the compression calc. should help alittle, if the link doesnt work. google honda compression calculator and look for the one on honda tech
www.c-speedracing.com/howto/compcalc/compcalc.php
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
