How loud can injectors be?
turn the key to run and pull the dizzy off but leave it plugged in. turn it by hand and you will hear the injectors. also if you rev it up to like 4 or 5k and shut it off then engine will still turn for a few moments without injector noise. this will point you in the right direction.
"Black people can't be racist" - Some black guy.
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
thats because ive had just about every problem known to man. not to mention im a genius.
Id say its LMA's and i beleive you can use the prelude LMA's like most people do on there B18s u just need to get the washers and they actually work better. PM jap I think thats who Kumar talked 2 about his
We are what we repeatedly do. Excellence, therefore,
is not an act but a habit.
-Aristotle
-Aristotle
Get the older version H22 LMA's with a 40 thousanths shim. My friend did the install of the new ones just 2 days ago for my car, its not that hard to replace em, just time consuming..
Good luck!
Good luck!
"Success is 99% failure" -Soichiro Honda
