NEED HELP!!! Massive Oil Leak...
i have a bad oil leak in my d16z6 under the cam gear.. what could it be?? should i say which seal broke?? is was not leaking like that before and out of nowhere its pouring oil out from under the camgear... is there a quick fix in this without having to do major work until i can afford a new gasket?? help will be greatly appreciated.. thank you..
PROBLEM FIX THANKS TO : rangcrx, freakasis, lzylst
THANK YOU GUYS FOR ALL THE HELP!!
my timing belt was off yesterday cuz u was changing my water pump!! thats f#@%d up!... which one do i buy?? http://www.discountautoparts.com/Sho...+Seals&mode=PA
if it happened when you took the timing belt off it might be your valvecover seal not camshaft make sure its nic and tight and flush with the head,if not get a new one autozone sells both cheap like 4 for the camseal and 11 for valve cover
i love AUTOZONE
i love AUTOZONE
my timing belt was off yesterday cuz u was changing my water pump!! thats f#@%d up!... which one do i buy?? 1995 Honda Civic - Indvidual Gaskets and Seals Parts -FELPRO- Discountautoparts.com
ruled out the valve cover that is ok, I when outside and checked and ruled the head gasket out too it is def the cam seal!! how do i change that seal if im not able to afford a mechanic??...
can somebody help me with my cam shaft seal?? i need to get it out and i need my car out by Saturday i have spent half a day in the internet (google) trying to find how to take my cam seal of so i can put the new one in.. but so far i have had no luck finding anything on my engine.. please somebody ill rep who ever helps me please!!...
