Compression Ratio help!!!!
Old Oct 25, 2008 | 03:08 PM
ASars's Avatar
Default Compression Ratio help!!!!
ok ive got a darton sleeved b16, 81mm bore im looking to run 20psi on it fully built bottem and top end ive gone all out on the build. now im ordering the pistons for the engine
im trying to get some pistons but cant figue out what compression ratio ill need, i dont want to go to low so i have no power but i dont want to crank it to high and detonate n blow my engine
ASars
SGT. U.S. Army
Old Oct 25, 2008 | 03:22 PM
omgwtfbbq!'s Avatar
I race sailboats
You knew enough to send your block to darton and to build the engine, but you don't know what CR to use? o_0
Just use 9:1 and call it a day.
Bitches don't know about the twin turbo
BLACK FENDER PART OUT
Old Oct 25, 2008 | 04:02 PM
k20tek's Avatar
cp 9.5:1
Old Oct 25, 2008 | 04:41 PM
60-1EK's Avatar
Engineer at the source
Bore it to 84mm and buy the CPs I have forsale. You will need all the help you can get on that little 1.6
JESUS SAVES
9.69@151 Street Car
JKOBD
Old Oct 25, 2008 | 06:02 PM
YARO's Avatar
Smith & Wesson Protected.
9.1:1/ 9.5:1/ 9.8:1 the highest
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Oct 25, 2008 | 06:24 PM
Todd's90's Avatar
0711, USMC
I'd do 9:1, if the bottom end is truly built then the lower compression will give you more room to run more boost safely.
1990 GS-T
1990 GST
2004 BMW 325i
Old Oct 25, 2008 | 08:39 PM
ASars's Avatar
ok ive got an eagle forged light weight crank, ragle forged h beam rods, darton 81mm sleves. iv got comp stage two sever stret, compition cams comp cam gears, comp valve springs, compe titanium retainers stage two port and polish i using a garret 60 trim t3/t4 at 20 psi my buddy told me if i run 8.8 compression ratio ill only be able to run 13psi or the cylinder pressure with be to great and caus detionation, other ppl have told me iwith the sleves and build ive got running i can use up yo 9.0 so what do you honda gurus think? ive ordered pistons from j.e. just need to get back to them on the compression ratio just looking for advice on my build.
ASars
SGT. U.S. Army
Old Oct 25, 2008 | 08:51 PM
YARO's Avatar
What your buddy "told" you is not accurate at all. Their are too many variables. I would go with 9.1:1cr. How much power are you looking for? and remember tuning is KEY!!
Old Oct 25, 2008 | 09:12 PM
ASars's Avatar
ok thanks I'm looking to use john vaga for tuning
ASars
SGT. U.S. Army
Old Oct 26, 2008 | 04:56 AM
rangcrx's Avatar
engine building &best
im with him if the block really is sleeved you better bore it out or you will be wasteing it,at least go to 83-84mm you will still be safe at 20Psi
i love AUTOZONE
