Compression Ratio help!!!!
Old Nov 18, 2008 | 10:47 PM
  #21 (permalink)
Pete Stop Motor Co.'s Avatar
Originally Posted by ASars
ok ive got a darton sleeved b16, 81mm bore im looking to run 20psi on it fully built bottem and top end ive gone all out on the build. now im ordering the pistons for the engine
im trying to get some pistons but cant figue out what compression ratio ill need, i dont want to go to low so i have no power but i dont want to crank it to high and detonate n blow my engine
Then a 9.5.1 should work well for you!
Old Nov 18, 2008 | 10:51 PM
  #22 (permalink)
ok thanks I'm looking to use john vaga for tuning
vega is a very good tuner! But when you get done tuning it with him bring it buy, bet i can get 10whp plus on his tune! And wont be to much! THANKS, CARTER
Old Nov 18, 2008 | 11:02 PM
  #23 (permalink)
biggoofy's Avatar
S1's body guard
im runnin 9.8:1 on 18lbs
SQUADRON ONE
NIKON D60 / 18-55 VR / 55-200 VR /
1994-integra ls j fronted on boost 348whp
1996-integra ls-vtekkk dd
Old Nov 18, 2008 | 11:47 PM
  #24 (permalink)
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Originally Posted by 60-1EK
Seriously guys. This isn't 1990. Running 10:1 compression and 30+ psi boost is completely doable with the proper tuning and setup.
+1.
I laugh when I watch people do builds and go lower than 9.5:1 to be able to"run more boost".
-Winston Churchill
Old Nov 19, 2008 | 02:44 AM
  #25 (permalink)
ASars's Avatar
lol yeah im not the most knowalageabl about the 4 cylinder builds sleving and all this is a mystery to me, lol but im learning as i go and every ones tells ya some thign diffrenent so i gotta see what happnes, you know throw it at the wall and see what sticks
ASars
SGT. U.S. Army
Old Nov 20, 2008 | 05:38 PM
  #26 (permalink)
SmokinS13SR20's Avatar
That ginger...
Call JE, arrange to send those pistons back and get the right ones.
If you plan on sleeving it still, do it. Sleeve it and run 9.5:1~ comp. ratio.
9.5 is NOT to high, John Vega will know what to do with it.
Boost loves compression. Your buddy is completely wrong with the 8.8:1 compression ratio comment. Yes, your cylinder pressures will be higher with a greater CR and more boost, but you are/were planning on running a fully built bottom end, it won't be a problem.
You will hate having a 8:1 CR, spooling the turbo will take forever and you will have very low 'off-boost' power.
Old Nov 22, 2008 | 06:59 AM
  #27 (permalink)
ASars's Avatar
cool, thanks man im guna get on the phone with je on monday. aprecate your advice.
ASars
SGT. U.S. Army
Old Nov 22, 2008 | 05:22 PM
  #28 (permalink)
That ginger...
Good luck, keep us updated.
Old Dec 7, 2008 | 02:58 PM
  #29 (permalink)
ASars's Avatar
well i called je the next monday pistons are already on theyre way out so im just guna run em as is for now till i future build
so ill berunning a b16a2 with
comp sever street/compitition cams
oem cam gears
comp steel retainers
oem valves
performance head gasket
je 8.0-1 cr forged pistons
je nitrogen piston rings
eagle h beam forged rods
eagle forged lightweight cromoly crank shaft
oem sleeves 81mm
garet 60 trim t3/t4 9at 30psi)
venom intake manifold
thats the pasic componets of the engine got lots of aditional stuff but thats the main shit for the engine
ASars
SGT. U.S. Army
Old Dec 7, 2008 | 03:16 PM
  #30 (permalink)
rangcrx's Avatar
engine building &best
get rid of this usless item"eagle forged lightweight cromoly crank shaft"and buy a valveTrain with TT retainers and ss valves,and a nice clutch set
i love AUTOZONE
