Vtec not kicking in
maybe a bad oil pump but if your oil light isn't lit-up, I doubt your pump is bad. maybe the vtec oil pressure switch is bad. those run around $50. try the parts for sale section to find one cheap.
"The richest man is not he who has the most, but he who needs the least."
TR "Old Skool DA" Member #28
does your solenoid have the pressure switch on it? some jdm ones do not, and if you are running a usdm ecu it will obvously throw that code.
the truth!
when is it clicking? when you reach X rpms? or when you put 12v to it? if you put 12v to it at idle does the sound of the engine change?
Sometimes when you have a good size dent in your oil pan you will not have enough oil pressure. What do you have this motor in? I would get a oil pressure gauge from the auto parts store and check it.
sucks man i had this problem before too.
could be anything check your ecu to see what code is throwing you.
This is what 18 holes smells like!
RIP Pablo 3rd Garcia will be miss By Millions 9/28/85-9/4/2007
TR "Old Skool EF" Member #147
only reason i know is bc the head i bought for my setup has a jdm solenoid and i had to ground it and disable the code completely in my ecu via crome. but i believe if a STOCK ecu doesnt pick up a pressure switch (which i believe was the code he said he threw) then it wont allow vtec to engauge.
