Vtec not kicking in
Old Oct 24, 2008 | 04:13 PM
  #21 (permalink)
JoKiE crx4294's Avatar
popeye built!
you have to make sure you get the dohc vtec fluid also, otherwise it wont work.
Can't spell strength without tren
AAS...It's whats for dinner
Old Oct 24, 2008 | 05:04 PM
  #22 (permalink)
jfr32988's Avatar
EL REY COLOMBIANO
ok these are the exact codes
21 VTEC spool solenoid valve
23 Knock sensor
Old Oct 24, 2008 | 08:27 PM
  #23 (permalink)
freakasis's Avatar
23 Knock sensor
that sounds better.
Old Oct 24, 2008 | 10:22 PM
  #24 (permalink)
sleepinsol's Avatar
starting over
if your knock sensor is not working i dont think it will allow vtec to engage since the ecu will have no way of detecting detonation. code 21 is the pressure switch code. is it wired right? maybe try running a wire from the harness to a ground somehwer to fool the ecu?
Old Oct 25, 2008 | 04:13 PM
  #25 (permalink)
killswitch95's Avatar
Originally Posted by sleepinsol
does your solenoid have the pressure switch on it? some jdm ones do not, and if you are running a usdm ecu it will obvously throw that code.
wierd i didnt know that ....i have a jdm b16a on a usdm p28 and when i dropped in the swap and took it for a test drive vtec worked fine for me.
maybe bcuz its b16a already has the pressure switch?
TR 5th gen civic crew #42
