help cel
i try yesterday and it blink and the it pulse and blink and pulse and so on..it kept doing that so i really didn't know what type of code it was throwing....
Racing Integration
1717 E. Busch blvd. ste# 403
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Your #1 source for everything from a oil change to 600hp+ engine builds !
ONE STOP FOR ALL YOUR IMPORT PERFORMANCE NEEDS
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
another thing the car jerks while I'm driving..(sometime)
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Make sure you are putting in the jumper wire before you turn the car to the run position. So Key off. plug in jumper wire, then turn key to run position. that should work.
www.myspace.com/chrisbowes
Solid blinks are ten... quick blinks are 1. So 1 solid flash and 2 quick flashes equals 12 as stated previously. Good luck.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
so if its the egr..that's why i smell fuel coming inside of my car?
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Honda-Tech.com: Honda Civic/Del Sol (1992 - 2000): THE NEW CEL THREAD (HOW-TO & CODES)
Read that ^
Hopefully this helps answer some of your questions.
If you read that and still don't know what to do. Bring your car to a shop to get checked out.
Read that ^
