help cel
help cel
i been looking and reading but i this havnt found my answer to my question...i had a bad misfire..i changed the spark plugs,spark plugs wire,distributer cap,and distributer rotor and its running a lot better but the damn cel pops up still i dont know what it can be...when i turn on position the cel stay off....NOW FOR MY QUESTION CAN I STILL CHECK MY CEL WHILE THE CAR IS RUNNING?
PLEASE HELP ME OUT!!!!
Racing Integration
1717 E. Busch blvd. ste# 403
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Your #1 source for everything from a oil change to 600hp+ engine builds !
ONE STOP FOR ALL YOUR IMPORT PERFORMANCE NEEDS
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
i know thats how you do it but the cel goes off when i put the ignition on and the car off...thats why im asking if i can do it while the car on.
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
You still check the code, its stored in the ECU until it gets reset.
so i can still check it even though the cel is not on?
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Yes, now go check it and we'll give you the best tips we can on how to fix it.
everytime i looked for a code on an OBD-1 car after i shut it off, i get nothing. but yes you can check for codes while its running. this is how ive done it almost everytime.
alright thanks
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
so while the car is running it gives you the right code?
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
Racing Integration
Tampa, FL 33612
Ph. 813-935-6720
Fax. 866-375-4960
