crx si ls swap help?
im trying to make a parts list of what i will need to put a 94 ls motor into a si crx
this is what i currently know
i need b series mounts
90-93 integra shift linkage,clutch cable,engine harness.
i was reading that i need to shorten the shift linkage? true or not?
90-93 integra hubs because of the axles? someone explain please?
ls ecu
anything else that i might be missing? or need to do?
ls ecu
well youll need b series mounts, u can cut a linkage to shorten it but i wouldnt do it your better off buying a linkage from hasport, cabl transmission, obd0 to obd1 convrsion harness, the hubs shouldnt matter but its something you could look in to, ls ecu obd1 suggest a p75. there is more but thats the jist of it.
Growe Motorsports Racing
C.T. Photography
REP IS ALWAYS APPRECIATED AND RETURNED!
Growe Motorsports RacingC.T. Photography
ls ecu
ls ecu
TR "Old Skool EF" Member #63
i was reading that i needed a shorter alternator belt because of clearance issue and to bang in like 4" or something like that, didnt really understand without a visual.
if your distributor is obd0 then yes. and no u shouldnt need another belt u just need to bang out a spot in the engine bay to the pulley wont hit it.
C.T. Photography
I take it this is your first swap? Try going to hondaswap.com & honda-tech.com do some searching also look on here. Their is alot of info on swaping. Their is also wiring that needs to be done.
DPFI to MPFI writeup
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
T & C Racing
FT Crew Mascot lol
