endyne breathe
Old Sep 10, 2008 | 06:10 AM
KJ's Avatar
KJ
bored at work
The way I setup cars for around 500ish is I weld two -10's to the back of the valve cover and run those to a catch can made or 3" square aluminum tube 6" long with a 1.5" outlet and filter I weld two -10's to the front of this can and connect those to the valve cover -10's and then I weld two more -10's to the lower portion of the can and run those to the back of the block as another vent location and also a drain back. On the back of the block you remove the hex plugs and either weld steel -10 fittings to them or since they are hidden I usually buy the oem honda fittings in the Endyn ($5 each) and just hose clamp the -10 line to them.
This setup works great, biggest cost is the lines and fittings, I'd guess it costs about $300 with all stainless lines. If you plan on making over 600 you should look into a "T1 style" can that sits in the battery location.
If you want something relatively cheap, I'll sell a kit I made very similar to the endyn setup for $75. It is used and has rubber lines and vents off the back of the block and returns to a modified stock breather tank. If you look at my old build thread you can see how I made it.
Old Sep 10, 2008 | 06:35 AM
Alpha's Avatar
But KJ. What do you use two -16 bungs on
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Sep 10, 2008 | 07:25 AM
KJ's Avatar
KJ
bored at work
1000 WHP mythical motors that never get built/started.
Old Sep 10, 2008 | 02:14 PM
biggoofy's Avatar
S1's body guard
im looking to make 450-500 on this setup i have a shop up here that i need to talk to about doing the work i wish i was still in tampa it would make things alot easier
SQUADRON ONE
NIKON D60 / 18-55 VR / 55-200 VR /
1994-integra ls j fronted on boost 348whp
1996-integra ls-vtekkk dd
Old Sep 11, 2008 | 06:45 PM
TypeSLO's Avatar
t1 catch can setup. woot!
Old Sep 13, 2008 | 12:16 PM
luvsracin87's Avatar
turbo hhhmmmm?
i have a used endyne catch can has the two fittings in the can and the moroso filter, no brackets or lines $70 lmk
813-478-4493
Steve: (813) 810.4146 <~ call or text
Old Sep 17, 2008 | 08:37 PM
  #17 (permalink)
T4eg's Avatar
haha how you been KJ?
plus the endyne kits 99% of the time fill with oil, i stopped using them few years ago and just stick to fittings on valve cover like stated above
9.81@ 155 - turbo street B18 retired SOLD
9.91@ 144 - turbo street 10.94@ 137 225 50 bfg stock block
9.10@169 - turbo street 24.5 mt
9.38@ 144 all motor
8.76@ 176 outlaw street
www.clutchmasters.com
www.tempestracing.net
