clutch pedal problem
Old Aug 26, 2008 | 07:04 PM
Marc's Avatar
Default clutch pedal problem
94 honda civic ex
the pedal has no presure ...it just clicks back and you have to pull it back up .... do i need to bleed the line ?
if so whats the best way to do that ?
Old Aug 26, 2008 | 07:14 PM
jlude90's Avatar
aspiring luder
just like you bleed the brakes except at the clutch slave cylinder
Old Aug 26, 2008 | 07:16 PM
Marc's Avatar
i tried that ... it still didnt fix the pedal problem .... does it suck air back in when you release the slave cylinder ?
Old Aug 27, 2008 | 06:31 AM
ekhatchboy's Avatar
Redrocket part 2
seals may be bad?
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Aug 27, 2008 | 06:36 AM
hondachris1994's Avatar
hatchback1994
Fill the clutch master all the way up with fluid, then put the cap back on and pump the clutch pedal about5-6 times, then openb up the clutch master again and add fluid. continue to do this until the pedal gets harder. If it doesnt get harder, check for leaks at the clutch master and the slave, make sure u look inside the car where the cluch master bolts to cause alot of the times they will leak from there
Old Aug 27, 2008 | 07:46 AM
sprjit22's Avatar
Rick James bitch
If your not too far away Ill bring my vacume pump and vacume bleed it for 20. LMK 863-236-8024 Terrry (Im in Tampa/Clearwater)
TR 5th Gen Civic CREW Member #14
T & C Racing
What VP Race fuel's should we carry?
FT Crew Mascot lol
Gotta love my hater fan club. I love the fact people worry about me 24/7 Ill never be forgotten. I love you guys.....
Old Aug 27, 2008 | 07:49 AM
Cone Killer's Avatar
Either your master or slave are bypassing the fluid, which means one or both need to be replaced, or your clutch is bad. I doubt bleeding it will do any good, it's a closed system, so if air gets into the line, or the master goes empty, then you most likely have a leak somewhere.
