Breather filter on valve cover/head
Old Aug 6, 2008 | 12:58 PM
freakasis's Avatar
Originally Posted by KJ
I believe Honda intent is to push air into the valve cover in order to force the oily air out the factory pcv box/valve due to the side in which the factory slash cut is done. The system relies upon the engine vacuum at idle pulling on the pcv valve and then at higher rpms full throttle (no vacuum) to use the velocity of the incoming air on the slash cut tube in the intake pipe to force the breathing. So basically at idle using manifold vacuum and at wide open when there is little manifold vauum using intake velocity.
Honda wasn't really designing around 12:1 compression na motors going to 9k+ or cars running 30 lbs of boost. In those cases the crankcase builds up too much pressure that this system no longer works and that is why on those apps a crankcase breather system either veting to atmosphere or being mechanically ventilated by other means.
iv never felt air comming out of the intake tube while the throttle was open...of course i never felt it at WOT with load on the engine but as far i as can tell air is always comming out of the valve cover and being sucked into the intake tube. and therefore a filter is pointless. just connect it up like honda did unless you have some sorta forced induction.
Old Aug 6, 2008 | 02:44 PM
jlude90's Avatar
aspiring luder
honda did it pretty well KJ, but like on my H22 and F20 it just doesn't do a good enough job, i guess thats why i have a problem with the stock system
with my B20A3 though i never had a problem
Old Aug 6, 2008 | 02:47 PM
civicized's Avatar
I rigged up a vaccum gauge once with a rubber gasket and never got vaccum from the hose nipple on the intake tube no matter how much throttle given. I have never checked it for pressure. I know even at idle, there is a fair amount of pressure at the valve cover, which is what throws me.
Old Aug 6, 2008 | 02:48 PM
Red2GDSM's Avatar
In the making...
Dont you mean K20A3?
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
Old Aug 6, 2008 | 03:38 PM
OMGVTEC's Avatar
Retired Moderαtor
its a B series block with a K head lol j/k
B20A3 comes in the 3rd Gen Prelude
Old Aug 6, 2008 | 03:46 PM
Red2GDSM's Avatar
In the making...
ohhh i seee okie dokie didnt know that
Old Aug 6, 2008 | 06:17 PM
  #17 (permalink)
KJ's Avatar
KJ
bored at work
I never said the Honda system works worth a damn, that is just all I could come up with looking at their diagrams, lol. I build breather tanks for all the cars I build, NA and turbo.
Old Aug 6, 2008 | 07:34 PM
  #18 (permalink)
Sabotage's Avatar
slash
ahhh, the breather debate!
here's some more talk about it!
valve cover breather
meows meows
TRick Squad Member #3
VicPrez of IttyBittyTittyCommittee
Old Aug 7, 2008 | 11:57 AM
  #19 (permalink)
Red2GDSM's Avatar
In the making...
lmao where the hell did you get the lil popcorn guy.. hes cool haha
Old Aug 7, 2008 | 04:14 PM
  #20 (permalink)
That One Guy's Avatar
01' Integra.. Slowness
hell now i'm even more confused 0_o
