help! idel ?
at idel my car reves up and down (ruhhhh uhhh ruhhhh uhhhhh)it just started doing it out of the blue. i thought it might have been a vacum leak or something like that but i cant find any leaks. could it be o2 sensors? if you can help i would apreciate it. oh yeah my car runs perfect oother than at idel. thanks
Guest
Posts: n/a
y0u|2 f457 1dl3 v4lv3 h45 g0|\|3 1|\| 7h3 5h1773|2. 7h15 v4lv3 15 l0c473d 0|\| 7h3 u|\|d3|251d3 0f y0u|2 7h|2077l3 b0dy. Y0u c4|\| 317h3|2 |23pl4c3 17 |23pl4c3 y0u|2 3|\|71|23 7h|2077l3 b0dy \^/17h 17 0|2 |23m0v3 17 4|\|d \^/3ld (0|2 07h3|2\^/153 cl053) 7h3 h0l35 70 7h3 7h|2077l3 b0dy cl053d. 7h3 0|\|ly 07h3|2 p0551bl3 7h1|\|g 17 c0uld b3 15 7h3 1dl3 41|2 c0|\|7|20l v4lv3 0|\| 7h3 1|\|74k3 m4|\|1f0ld bu7 175 |\|07 v3|2y l1k3ly.
The guys above gave some good suggestions.
In order to know what is causing the problem though youre going to need to get a bit dirty and figure it out youself. Get some carb cleaner and with the engine running spray it around the intake manifold TB etc. If idle jumps youve found the problem.
If its a bad thermo valve when the engine is at op temp take off the FITV housing lid and stick your finger over the hole. If you feel suction then the wax pellet has become to old to expand and you will need to replace the FITV.
If none of that is the case it could be a sticking throttle plate (open a tad resulting in off-idle) leak in a vacuum line (use carb cleaner again) etc.
Did you do any fuel modifications?? When Cavy got some of her fuel mods done the idle got messed up. When I reved the motor the idle would fall and then fly back up. It would drop to like 200 rpms and then fly back up to around 1500rpms and then fall back down and stall sometimes. I got a FPR and it got alot better. I think I was running too much fuel.
