help! idel ?
When my idle starte getting a little crazy I removed the fast idle thermo valve and noticed the wax thing had backed itself out. I just screwed it back in and havent had the problem since. Same thing happened on my friends gsr screwed the wax thing back down and again the problem was fixed.
Gracie Barra Clearwater
Guest
Posts: n/a
0|2 y0u c0uld ju57 |23m0v3 17 3|\|71|23ly. 17 |234lly 0|\|ly 53|2v35 70 h347 up 7h3 7h|2077l3 b0dy du|21|\|g c0ld 574|275 70 h3lp b|21|\|g 7h3 3|\|g1|\|3 up 70 73mp. 4f73|2 7h47 4ll 17 |234lly d035 15 h347 7h3 7h|2077l3 b0dy up 4|\|d l1m17 4|\|y g41|\|5 y0u m1gh7 g37 f|20m 4 c0ld 41|2 1|\|74k3. 96+ H0|\|d45 d0 |\|07 h4v3 7h15 v4lv3 1|\|c0|2p0|2473d 1|\|70 7h3 7h|2077l3 b0dy.
Originally posted by "Someone"
Originally posted by Mr Self Destruct
or you could just remove it entirely. It really only serves to heat up the throttle body during cold starts to help bring the engine up to temp. After that all it really does is heat the throttle body up and limit any gains you might get from a cold air intake. 96+ Hondas do not have this valve incorporated into the throttle body.
you know something funny the idel prob just fixed its self im tellin you these crxs just find someway to fix theri selfthats like the 2nd or 3rd time something has screwed up on my car and i just let it go for a few days and it fixed itself? weird thank sfor the help though
Originally posted by UltraNosLS
So which one is it? Will your car run ok without it?
I think Bill and John were saying the same thing just in different terms. Bill described how it works by adding more air to the idle mix when it is cold outside john mentioned the side effect of it heating up the throttlebody.
essentially in FL you dont need it if you spend time up north during the winter then dont remove it.
Some part on the car is about to break and every once in a while it will malfunction. Eventually it will occur more and more frequently until it finally just gives up and breaks completely. Id figure out what the cause is before you get stranded on the side of the road with all our domestic friends.
