Help with swapped motor and tuning ...
Hi, kinda new at the motor swap thing. About to buy a 96 civic hatch with b18c and want to install a/c compressor to have a/c. I can't find anything on hasport... does anyone know where I can get a bracket for this? Names? Websites? Much appreciated. ALSO, I have been made aware that the eninge has been freshly rebuilt and needs to be tuned. How does Hondata work? Does it kinda work by itself? Meaning... If i plug it in, run the car, will it tell me what I need to adjust? I don't want to F the car up. Also, if YOU know how to use Hondata... could I pay for someone to help me? Thanks!!!!
Your local honda dealer will be able to get you the bracket & belt.
Use a 1995 Honda Del Sol p30 DOHC VTEC B16 a/c compressor bracket & belt.
Use the a/c compressor from the 1996 civic.
Concerning the tuning, check out https://www.tamparacing.com/forums/h...directory.html
I hope this helps
I hope this helps
