b16 block with gsr head
i'm wonder how my car will run with a jdm b16a bottom end with a fully built gsr head lmk asap b/c i'm looking to do that or going back to an ls vtec lmk what would be better and which head gasket i would use gsr or b16 don't know if there is even a difference in the two thanks alot
engine building &best
on
well if you do the gsr with b16bottom the car will run the same as if it was a B16,save up and use your built gsr head on a gsr or Lsvtec
i love AUTOZONE
i love AUTOZONE
on
just rebuild your lsvtec then you have a nice FREASH reliable motor.and you can use lil extra monet and make the bottom at strong as the topend
i love AUTOZONE
i love AUTOZONE
ls/v-tec all the way.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
Who ever said a b16 with a gsr head is the samething as if it had the b16 head is crazy. The gsr head has a way bigger combustion chamber than the b16 the intake ports on the head are at a diffrent angle than the b16 the gsr head is twice better flowing than any bseries head. Plus with the gsr head you will automatically raise the compression depending on the bottem end if you have the newer jdm b16 motor with the p30 pistons and the right head gasket (by the way both heads use the same headgasket) compression will almost be close to 12.2.1
i really hope this clears some things up. dunno where all that info came from but i did tons of research b4 i did my ls vtec conversion about which head to get. but on a side not a gsr head on a b16 cant hurt. the extra compression is always a plus.
