TURBO CIVIC
Old Jul 23, 2001 | 05:37 PM
COQUI2376's Avatar
i have a question. i just got a turbo kit installed at racing zone. i have a 2000 civic ex obd 2 and the turbo kit is a drag gen 3 . the problem is that at 5000 rpm in 345 gear the car is cutting off the boost. racing zone said that it needs more check valves. i put in 3 more check valves because they said the last car they did had 6 and all my car had was 4. with 8 it is still doing the same thing. the check light in the car is not turning on when it does it. i have no clue what to do. does anyone know what to do. do the check valves need to be in front or after the map plug.( have them before the plug). SOMEONE PLEASE HELP
Old Jul 23, 2001 | 06:08 PM
GOTTI's Avatar
OEM Parts Specialist
moving to honda/acura tech
Old Jul 24, 2001 | 04:54 PM
C VeX's Avatar
Cutting off Boost???????? So no boost what so ever correct?? Your check valves are there to release excess pressure before it hits the MAP sensor. In this case your OK your engine lights are not on. Check all your pipes connection make sure they`re tight.Hows your fuel?? maybe your leaning out.Ahhk so many problems with turbo.
Charles
Feb 1, 2001 04:31 PM
low4cyl
Dec 27, 2000 02:31 PM
e-racer
Oct 8, 2000 06:27 PM
knowledge112
Oct 4, 2000 05:22 PM
_Charles_
Aug 7, 2000 10:33 PM
