The Rebirth of Da Red Dragon
It is hitting pretty bad. I'd guess for about 30 degrees of crank rotation or so. I ran out of time to pull the cams back out and check the valve seal installation but they didn't look out of order when I installed the check springs but I also didn't study them too cloesly at that time.
Gracie Barra Clearwater
Like KJ said. Pretty bad. This is a different head than last time. Not a stupid question but yes. The seals are all the way down. Double checked last night
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
only double checked one
Tuning, Builds, Assembly, Turbo Installs, Repairs and More
inductionperformance.com
ALPHA TUNED
Only need to double check cylinder one
* IP E-Mail
* IP Face Book
* IP Web-Site
* IP E-Mail
* IP Face Book
* IP Web-Site
Here is what Skunk2 replied
Hey Xavier,
Here is a drawing I did to help illustrate the dimensions of our B series retainer.
Use this to compare against the retainers you have.
When I compare our retainer to what you had in the picture that you posted on the website, it appears as though your retainers are correct.
The retainers your friend posted look more like K retainers than B retainers.
We have done extensive testing and our retainers will clear factory valve guides and stem seals when used with any camshafts we offer.
The fact that you are experiencing clearance issues between the retainer and the valvestem seal indicates to me that either your installed height on the valvespring is too short, or you have aftermarket guides and/or valvestem seals that do not match factory spec.
I think that the installed height is most likely your problem.
Installed height for B series springs should be 1.320” on the intake side.
A few questions that need to be answered are:
1.) What keepers are you using?
2.) What valves are you using?
3.) What is your valvesprings installed height?
I hope this helps you clear up your issue. If there is anything else that I can do to help please let me know.
Brian Nichols
Skunk2 Customer Service
Hey Xavier,
Brian Nichols
ALPHA TUNED
so whats next? check installed height? did skunk2 mention what keepers you're suppose to be using?
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
My retainers are the part number 308-05-0300
Perhaps they mis-packaged them ?
Maybe they sent you the wrong cams ?
maybe you should sell them and get the roller rocker setup???
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
ummm yea NO!!!
boxes say stage 1 with part number
ALPHA TUNED
