How Can I Convert A 3 Pin Iavc Plug To A 2 Pin?
Old May 25, 2008 | 04:00 PM
lmgsr's Avatar
Default How Can I Convert A 3 Pin Iavc Plug To A 2 Pin?
I have a 96+ Civic EX (y8 engine) I'm going to put on a 92-95 EX (z6) intake manifold I need to switch the 3 pin plug to a 2 pin because the IAVC is for a 2 pin not a 3 pin. Thanks in advance for all the help TR...
Old May 25, 2008 | 05:31 PM
poorboy44's Avatar
TR Balla Donor Supreme
do you have the 2 pin plug? well if you dont, you're gonna need it. its a round style 2 pin plug with a green/black wire and a all black wire i believe.
first, you're gonna need to remove the orange wire from the 3 pin iacv plug. tape it up, you're no longer gonna use it. next splice the yellow/black wire from the 3 pin iacv plug to the green/black wire of the 2 pin connector. then splice the black/blue wire from the 3 pin iacv to the black wire of the 2 pin iacv. should be all done with this to tape it up and make it look pretty.
Next your gonna need to get to your ecu. you're gonna need to remove the a-plug out of the ecu, should be biggest plug all the way to the left. then you need to unpin #a-14 and move it to #a-12. then remove #a-13 and tape it up. should be good to go from here.
heres a pic of the ecu plug
http://www.ff-squad.com/tech/wiring/...-98_a-plug.jpg
http://www.inductionperformance.com/
R.I.P
Kevin "Slo_Si" Gonzalez
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
You will be missed and remembered forever!!!!
Old May 25, 2008 | 06:21 PM
lmgsr's Avatar
thnx it seems simple, I'll try it tomorrow and let you know how it goes.
Thanks again
Old May 25, 2008 | 10:21 PM
opiumdaze's Avatar
yep randy knows his shit!
Old May 26, 2008 | 06:47 AM
DemonCivic's Avatar
another diagram and write up, hope this helps
Old May 26, 2008 | 07:11 PM
lmgsr's Avatar
Thanks TR I did it and it came out good. Thanks for the info and help, you guys are gr8
Old May 26, 2008 | 09:13 PM
poorboy44's Avatar
cool, glad everything worked out for you
R.I.P
6/21/86-9/13/06
Pablo Garcia
9/28/85-9/05/07
