b16 crank pulley timing marks?
Old May 7, 2008 | 01:49 PM
JoKiE crx4294's Avatar
popeye built!
Default b16 crank pulley timing marks?
which timing mark do i use on the b16 crank pulley?
Can't spell strength without tren
AAS...It's whats for dinner
Old May 7, 2008 | 03:03 PM
zeroboost1's Avatar
I dont know off hand but if you take out the #1 spark plug and put a long skiny screw driver in the hole and turn the crank till the screw driver is at its highest point then the pully should be on the right mark. If you dont know wich #1 is its the closest to the driver ok hope this helps and gl.
CAM-Mobile-Performance&Repair
For All Your Performance And Repair Need's
Done At Your Spot Or Mine.
I do every thing from ECU chipping, swaps and custom wireing to audio and alarms, even suspention and alignment's.
We will be tuneing very soon E-MAIL me at CAMPERFORMANCE@yahoo.com
For any questions or to set up an appt.
Cory .M
Old May 7, 2008 | 03:10 PM
zedron's Avatar
The one that is all by itself.
Not any that are with the 3 in the group.
B20 Non-Vtec Turbo: 275whp/234wtq @ 8 psi 2/10/2007
LS/Vtec Turbo: ???whp/???wtq @ ? psi (Secret )
Tuned by John Vega @ Phearable.net
Old May 7, 2008 | 03:29 PM
zeroboost1's Avatar
you got it thank you sir adn to think all that typing for nothing lol.
Cory .M
Old May 8, 2008 | 07:52 AM
popeye built!
cool thanks guys.
Old May 10, 2008 | 12:26 PM
civicized's Avatar
He asked which timing mark to use, not which mark is top dead center. Not sure if he got his question answered properly or not if what he is trying to do is set his timing.
